Page 1 of 3
LOTW upload
Posted: 11 Jul 2021, 19:49
by pa3adu
hi,
Installed the new version 2.15.0.0 and since I have problems with the LOTW uploading via the QSL manager. Before this update, the uploading worked fine. I checked the settings in the external services and they look unchanged and the path to my tqsl is correct.
Any suggestions?
73, Nico PA3ADU
Re: LOTW upload
Posted: 11 Jul 2021, 20:23
Have you tried a direct tqsl upload?
What error message do you see in QSL manager?
Re: LOTW upload
Posted: 11 Jul 2021, 20:40
by pa3adu
have not yet tried a direct upload Terry.
error message in QSL manager:
INFO: ADIF File created successfully.
INFO: TQSL Version 2.5.1
No private TQSL Password set
Executing TQSL with upload
Messages from LOTW:
TQSL Version 2.5.1 [v2.5.1]
Final Status: Command Syntax Error(10)
Command syntax error
LOTW END
the message "No private TQSL Password set" is confusing for me. The manual says that "Not normally used".
I tried a tqsl private password but no luck (different error message)
Re: LOTW upload
Posted: 11 Jul 2021, 21:13
Please update Tqsl and try again
Re: LOTW upload
Posted: 11 Jul 2021, 21:31
by pa3adu
Not sure what you mean by updating tqsl.
Updating in what (Log4om?) and how.
Or do you suggets to download tqsl from the ARRL site again?
Re: LOTW upload
Posted: 11 Jul 2021, 22:24
pa3adu wrote: 11 Jul 2021, 21:31
Or do you suggest to download tqsl from the ARRL site again?
You need to open TQSL on your PC and it should say there is an update, follow the instructions.
I did state that on this release a TQSL update is required see--
viewtopic.php?f=1&t=6808
Re: LOTW upload
Posted: 12 Jul 2021, 20:10
by pa3adu
That was the trick.
Thanks for the help Terry!
73, Nico PA3ADU
Re: LOTW upload
Posted: 18 Jul 2021, 16:34
by F4HGU
Hello Terry,
I had the same issue on my side and had to update TQSL.
Afterwhat I faced to a second issue about the "station location" configuration is TQSL. In fact I was using "French acute accent" in the name of the location. That was working for TQSL in standalone but not thru Log4om.
My location was described as "Domicile Méré" then I changed it to "Domicile Mere" and that was OK. That was not causing any issue with previous Log4om versions.
If it can help other users...
Thank you for the strong support and for this very nice software !!
Patrice
Re: LOTW upload
Posted: 25 Jul 2021, 08:33
by DF5WW
Latest TQSL now 2.5.8. Please update if you use older versions.
Re: LOTW upload
Posted: 26 Jul 2021, 15:49
by W6SDM
I have updated LotW to 2.15.0.0. I've updated TQSL to 2.5.8. I'm having the same problem that I had before. I select the QSOs that I want to upload to LotW, press upload, and the message I get is:
INFO: TQSL Version 2.5.8
And then it hangs. Any help would be very much appreciated.
Steve, W6SDM
