SDR Uno SDR Play Log40MV2 2.15
rl2017
Post by rl2017 »
Using Kenwood TS-590SG, SDR Play RSP1, SDR UNO, Omnirig 1.9
SDR UNO and radio in sync
Unable to get Log40mV2 2.15 to have rig control as well.
All using same Omnirig .ini file
Are there specific settings I need to do to get this working??
SDR PLAY
SDR UNO
Log40m V2 all are Omnirig compatible.
K1RQS
Re: SDR Uno SDR Play Log40MV2 2.15
You need to run all programs that use Omnirig to 'Run as an administrator' including Omnirig
I have an almost identical setup, except for the radio model, an it works fine
See the user guide for instructions about running as an administrator
rl2017
Post by rl2017 »
Terry,
Thanks.
That did the trick.
I did not have SDRuno running as admin.
Yahoo!
