make tqsl options configurable
DB9CR
Post by DB9CR »
as a new feature, I request to make the options passed to tqsl completely configurable.
Especially, I would like to see
- Support -t option of tqsl to write a log file in case of errors
- Support disabling the -q option to get an interactive version of tqsl where all user interactions are done like when a user directly clicks on tqsl from the desktiop.
Thanks in advance - I hope you consider this.
73 de Christian DB9CR
Re: make tqsl options configurable
-t done in next release
DB9CR
Post by DB9CR »
From the release notes:
“-f update” added as an option in LOTW settings. This command is supported only on latest TQSL versions
Added an option in LOTW settings to set “-t” field on TQSL string. This will generate a TQSL_LOG.txt logfile in Log4OM settings folder /Temp. Settings folder is reachable from HELP menu.
Added an option in LOTW settings to start TQSL in interactive mode (Log4OM will start TQSL in a separated thread and then proceeds confirming the upload of the selected QSO. It’s user responsibility to ensure that QSO are correctly loaded into LOTW)
Thank you very much! That covers all my suggestions! Great work!
