Dear Daniele, Terry and Team.
My Wifi in my upstairs shack was awful, so I have put a Cat 5 cable in to my laptop.
Since doing this, I have suffered greatly with cluster drop outs, Super Cluster is fine, however.
Is this a Log4OM settings or a DXSpider settings sort of thing?
As always, thank you for your help and advice.
Kev
From Wifi to Lan - Cluster Drop Outs
Re: From Wifi to Lan - Cluster Drop Outs
You sure that you have not got a faulty cable it should be better than Wifi?
Logic says that as you stated
Super cluster is a internet function as opposed to the normal cluster which is Telnet so there could be a difference.
Have you tried other cluster servers? its not unknown for clusters to have issues!
We must assume its the cable causing the issue!Since doing this, I have suffered greatly with cluster drop outs,
Hi, Terry.
No, the cable is fine, it fed two Ras Pi for 12 months or more with no issues.
I’ve stopped using these units now so decided to utilise the cable.
Kev
Kev
