"Solar data" menu item under the "View" menu
EI4HQ
Post by EI4HQ »
Version 2.16.0.0
Clicking on the "Solar data" menu item under the "View" menu results in no window appearing. In the log viewer, the following error message appears each time the menu item is clicked:
05:25:16.729 Error: [#=zCVI7SuoKiQbEE30gemHMKJNGZ$vx][#=zCfXzbHZhthjrtnJPhA==] : [EXCEPTION] Could not find any resources appropriate for the specified culture or the neutral culture. Make sure "#=zzbA3kYPpI2aen000aZCyF4kHPOE2.resources" was correctly embedded or linked into assembly "L4ONG" at compile time, or that all the satellite assemblies required are loadable and fully signed.
BR
Cormac, EI4HQ
[Cobh IO51uu / UTC] NNNN++++
Re: "Solar data" menu item under the "View" menu
Seems there is a bug I will point Lele to it, thanks
EI4HQ
Post by EI4HQ »
Welcome.
BR
Cormac, EI4HQ
