Lost config setting again - not able to restore last saved .json file
Re: Lost config setting again - not able to restore last saved .json file
When you copy and paste the config file to the user folder is Log4OM open? you should do the copy and paste with Log4OM closed then when you open it it will use the config.json
That file is created automatically each day to ensure you have something to revert to in the event of an issue and no backup set.
Is your restored 'config.json' working OK?
The config.json looks fresh (only 13 KB). Rename the config.json to old_config.json and rename the last_valid_config.json
to config.json and restart again.
Do you have any backups?
