Reception Reports Question
Posted: 04 Sep 2021, 20:08
by WA2ANG
Greetings:
Getting to know and use the Log4OM2 program, trying to gain experience daily
Its gradually becoming my sole logging program, I have a question concernng reception report entry.
Thre program has both a receiving and sending report box with a pulldown to select signals i.e.(599).
Is there a way to to enter my own entry? Often I use digital programs that use SNR for signal reports, and I would like to be able to enter SNR reports as well as convnetional reports.
Please let me know if this can be done, or how it can be done.
Tom
WA2ANG
Re: Reception Reports Question
Posted: 05 Sep 2021, 11:52
by DF5WW
If you work modes which using SNR reports in -dB or +dB they will be logged in this format. With
this modes it´s impossible to have a correct RST so the meter show´s only the loudest signal in
the digital "channel" which is a 3 kc USB segment. If you check the pulldown if you select a mode
like FT8 or FT4 you will see that the pulldown has changed to dB instead of an RST.
Posted: 06 Sep 2021, 00:32
by WA2ANG
Greetings
When I go to user preferences, I select psk31, JS8, and FT8 and save/exit. When I enter my contact info into the log window. I select digital mode JS8 And Psk31 -I do not get pull down menus for SNR signal reports. When I select FT8 I get pull down for SNR values but it does not appear for other digital modes
Am I doing something wrong?
Thanks Tom WA2ANG
Sent from my iPhone using Tapatalk
Posted: 07 Sep 2021, 15:18
by WA2ANG
WA2ANG wrote:Greetings
Thanks Tom WA2ANG
Please respond to my last post above
I only get SNR drop down for ft-8 and not js8 or psk31 - Am I doing something wrong?
Tom
Posted: 08 Sep 2021, 05:03
by DF5WW
Normally there isn´t to do something wrong. That informations coming from the rst file. It´s an XML and stored
in the Log4OM configuration folder. What version of V2 you are using ? (See Help/About).
As you can see in my screenshot it works well on my side:
You may also try my rst_user file. You can copy it in the folder where you find the rst file. You don´t
have to delete the original files so _user files override the original ones.
rst_user.xml
(24.12 KiB) Downloaded 283 times
Posted: 03 Oct 2021, 00:52
by Ab6kx
I am having this same issue. when selecting mode FT8 it is properly offering db signal options but when selecting js8 its giving rst option which is not valid for JS8. I believe that the issue may be related to needing a JS8 entry in the RST.xml file. Just my thought. Im using version 2.17.0.0
Posted: 03 Oct 2021, 02:10
by KI5IO
Dave,
If you download the rst_user.xml file that Juergen posted above you can open/edit that file in a text editor and add the codes for JS8. Then save that file in the location where you find the rst.xml file.
Do NOT delete the rst.xml file as that gets updated with new updates of Log4OM V2. The xml file with the _user tag is yours and does not get over-written.
Danielle (as I recall) likely has adding JS8 and related information to the rst.xml for a future release.
But ... in the meantime you can modify that file from Juergen and give it a go until Danielle gets it added.
Posted: 03 Oct 2021, 04:03
by Ab6kx
Thanks, that will work for now
I appreciate the help
