CAT not working correctly on FT900
K6KA
Post by K6KA »
When using Omnirig with parameters set to the FT900 manual Log4om defaults to 8o meters defaults to 3700.00 the radio shows the correct Freq (all bands). If I use Hamlib the program defaults to the correct freq but the radio will not change freq. again Hamlib set to the correct FT900 manual specs. Specs are Comport correct of course Baud rate 4800 Data Bits 8 Parity none Stop bits 2 RTS high DTR high Poll int 500 Timeout Ms 4000 for Omnirig.
Hamlib Serial Connected radio Baud 4800 Stop bits 2 RTS and DTR checked no PTT Poling 50ms
Can anyone tell me what I need to do to get the correct response from radio to Log4OM or vice versa on the FT900? BTY the radio is selected in both management programs.
Re: CAT not working correctly on FT900
1. Log4om version number? Help/about
2. Are you running any other programs at same time?
3. What version of Omnirig?
4. Are you running Omnirig and Log4om as an administrator?
5. Has your radio ever functioned correctly with CAT control On this pc?
K6KA
Post by K6KA »
1. Log4om version number? Help/about Version 2.17.0.0
2. Are you running any other programs at same time? No
3. What version of Omnirig? Version 1.9
4. Are you running Omnirig and Log4om as an administrator? Yes on Both
5. Yes if fact I loaded Amateur Contact Log and tested worked as it should have
Alex has released version 1.20 of Omnirig and a new set of rig descriptor files I suggest that you install them and try again.
Do not download the Omnirig version from the Swiss site it will not work, only use the DXAtlas original site.
K6KA
Post by K6KA »
Thanks for the info however I got the same results with version 1.2 omnirig
K6KA wrote: 26 Sep 2021, 21:18 Thanks for the info however I got the same results with version 1.2 omnirig
Have you tried a different ini file like ft857?
K6KA
Post by K6KA »
Went through almost all Yaesu radios with no luck. I thought the 450D would would since all parameters except baud rate would work but would not.
K6KA wrote: 26 Sep 2021, 22:28 Went through almost all Yaesu radios with no luck. I thought the 450D would would since all parameters except baud rate would work but would not.
Try a factory reset of your radio
K6KA
Post by K6KA »
Not sure that would work since CAT works fine with other programs.
K6KA wrote: 27 Sep 2021, 17:42 Not sure that would work since CAT works fine with other programs.
Up to you but I have had this before where a radio works with some software but not others because the radios CAT chip had got confused.
