IC-705 and LOG4OM/Omnirig
g3yiq
Post by g3yiq »
I'm trying to set up the LOG4OM connection between my PC and an IC-705 but this transceiver does not appear in the Omnirig CAT settings. What's the best way to resolve this?
73 Bob
Re: IC-705 and LOG4OM/Omnirig
Have you updated to the latest rig files released a couple of weeks ago?
Did you try similar Icom rig files like 7000 or 706?
Did you instal the Icom USB drivers before connecting the radio to the pc?
g3yiq
Post by g3yiq »
I had a fresh in stall of LOG4OMm and Omnirig but will check for Omnirig updates.
I tried the IC-7610, but didn't know which rigs are similar regarding settings. I'll try others.
I had connected the rig to the PC over Bluetooth. Will try USB and check for driver installs if I can't get that to work.
Thanks, Terry
Pretty sure Omnirig and Hamlib do not support Bluetooth
PE5TT
Post by PE5TT »
The bluetooth connection creates a virtual com-port on the PC, i see no reason why it can't be used by any cat software.
However it might be wise not to start that way and first get it running via a cable.
A Google search reveals the IC705 is supported by latest Omnirig ini files and also found this discourse which might assist
https://sdr-radio.groups.io/g/main/topi ... h/77704841
