IC-705 and LOG4OM/Omnirig
Posted: 28 Sep 2021, 12:07
by g3yiq
I'm trying to set up the LOG4OM connection between my PC and an IC-705 but this transceiver does not appear in the Omnirig CAT settings. What's the best way to resolve this?
73 Bob
Re: IC-705 and LOG4OM/Omnirig
Posted: 28 Sep 2021, 12:19
Have you updated to the latest rig files released a couple of weeks ago?
Did you try similar Icom rig files like 7000 or 706?
Did you instal the Icom USB drivers before connecting the radio to the pc?
Posted: 28 Sep 2021, 19:23
by g3yiq
I had a fresh in stall of LOG4OMm and Omnirig but will check for Omnirig updates.
I tried the IC-7610, but didn't know which rigs are similar regarding settings. I'll try others.
I had connected the rig to the PC over Bluetooth. Will try USB and check for driver installs if I can't get that to work.
Thanks, Terry
Posted: 28 Sep 2021, 19:43
Pretty sure Omnirig and Hamlib do not support Bluetooth
Posted: 29 Sep 2021, 10:40
by PE5TT
The bluetooth connection creates a virtual com-port on the PC, i see no reason why it can't be used by any cat software.
However it might be wise not to start that way and first get it running via a cable.
Posted: 29 Sep 2021, 16:55
A Google search reveals the IC705 is supported by latest Omnirig ini files and also found this discourse which might assist
https://sdr-radio.groups.io/g/main/topi ... h/77704841
