Temporary loss of rig interface
WA2SQQ
Post by WA2SQQ »
I regret that I cannot provide more details, but I've been experiencing a minor issue about once a week. I use LOG4OM with my FLEX 6500. Occasionally, the connection between the FLEX and LOG4OM is lost. All other resources using the same interface / CAT commands work fine. I reboot FLEX's CAT program and all goes back to normal.
Just thought I'd mention this in case anyone else is experiencing this.
ve3wej
Re: Temporary loss of rig interface
Post by ve3wej »
I have a 6300 instead, but same issue. this is only when I use hamlib for cat, via tcp port. I switched back to omnirig for cat control and it has worked just fine.
I do not run either in admin mode
Dave ve3wej / ve3ie
