This happens in both REcent QSO list and QSO Archive list.
After I find some record, make an edit and save changes, list is reloaded, scrolled to the top )newest record) and pointer to edited record is lost. I have to scroll down and search for the record again.
This make things like serial editing records really hard to do. For example, as new award manager is introduced I wanted to go through the log and edit entries to add award data. Each time I edit one record table is reset to the top and I have to search again where I was.
REcent QSO list and QSO Archive list resets after edit
Re: REcent QSO list and QSO Archive list resets after edit
Hi Pedja,
That's something I mentioned already many months ago but I think this will be hard to fix (with a refresh).
As a work around, don't click on "Save And Exit" but on "Save" first and than on "Cancel". Then you will continue where you was before, but without a refresh.
Claus, EI7JZ/OE6CLD
Claus, EI7JZ/OE6CLD
Claus, OE6CLD/DJ0DX/EI7JZ
Hi, i'm aware of that situation, working to fix it in a next release.
If changes are all the same you can use the "massive update" function: filter all QSO with the same manager, select them all and use the massive update function to fix all of them in a single pass.
Anyway i should work to make refresh working better
