Hi All,
I have found Log4om2 is hanging when I shut down.
The only way to closedown is to use Taskmanager.
Has anyone had this problem, or, indeed, solved the puzzle?
Best Wishes
Brian G0VAX
Log4om2 Hangs when shutting down
Re: Log4om2 Hangs when shutting down
I'm getting the exact problem on shutdown, Log4OM just hangs, if I disable auto upload it closes without any issues. Started having problem on 30th October trying to upload 200 QSO's worked in the CQ world wide DX contest. Has been working perfectly, is there a solution for this?
Version number?2E0SPS wrote: 02 Nov 2021, 11:10 I'm getting the exact problem on shutdown, Log4OM just hangs, if I disable auto upload it closes without any issues. Started having problem on 30th October trying to upload 200 QSO's worked in the CQ world wide DX contest. Has been working perfectly, is there a solution for this?
Version 2.17.0.0 looks like it started after update.
I've found a workaround you have to tick both "TQSL Interactive mode "and "Automatically upload on application close" for it to work.
Tried this and upload to LOTW successfully and Log4OM closed with no issues
I had the same problem and tried enabling the interactive mode. When I shutdown a pop up window advised there was a new version of tqsl which I allowed it to install.
I then restarted log4om and disabled interactive mode and it shutdown just fine.
2E0SPS work-around fixed the problem for me!
THANKS
THANKS
