dual VFO - PTT issue
iz8ewd
Post by iz8ewd »
I use Yaesu FT-991A, controlled by CAT with FLrig, LOG4OM v.2.17.0.0 is configured to connect to hamlib rig model 4 and VFO MODE is selected.
LOG4OM displays correctily the two VFOs, if I set split mode it also shows correctly rx and tx indication, when I press the PTT via CAT using the dedicated keyboard key "\", the radio goes in transmit but doesn't go back in rx when I press it again. The PTT command works well when split is not used.
