LOTW will not up load
pa3adu
Post by pa3adu »
suddenly I have a problem with uploading the LOTW contacts via the QSL manager. I was using ver. 2.15 and in order to fix the problem I installed ver. 2.17.
Tried to upload 2 QSO's via de QSL manager and this was as expected and loaded into LOTW. Then I sellected a full page (90 QSO's) and got the same problem. QSL manager opens the upload window and when clicking the green button, I see a message "LOTW END", just that. Sometimes it looks like it will upload but the upload windows stays in that position for ever.
I checked my TQSL which is ver. 2.5.8. and the Configuration Data Version is 11.15. Downloading seems to work okay.
any suggetions?
73, Nico PA3ADU
pa3adu
Re: LOTW will not up load
Post by pa3adu »
I managed to upload a few QSO's by selecting them from the list in the QSL manager. This does not work very stable. When selecting e.g. 5 calls, the uploading is "hanging" and I have to close LOG4OM. After restart, again a few calls seems to work but when selecting more calls the either the uploading is hanging or I get the message "LOTW END" (just that).
pa3adu
Post by pa3adu »
Figured out the problem!
Main cause of the LOTW upload issue was in the list that I tried to upload. Some QSO's were made during the JOTA event using an extenstion to my call sign (PA3ADU/J). Since the tqsl is only valid for one call sign (in my case PA3ADU), LOTW rejected my upload. Unfortunately, the upload screen did not show this message. Instead it just hang and waitinng until I killed the program completely.
Maybe here is some room for improving the error handling of the upload screen.
Although this is the main cause, I still had some issues uploading a list larger then 10 QSO's. But so far this is working for me.
Nico PA3ADU
