ADIF export file is not sorted according to the Qsos date
F6FLU
Post by F6FLU »
I have a problem exporting my file in ADIF format.
The first 2 exported QSOs are not in the order of the QSO dates.
I always have UB50/M first QSO Date = 20210523 12:44 the next is always R4ZW/p QSO Date = 20210523 12:50
Then it is in the order of date of QSO :
YU5FF 19780403 09:10 then F2JD / P 19780403 09:24 etc ...
How to make so that the first 2 QSOs displayed in this ADIF file can be exported sorted on the date of the QSO?
In summary, I would like the full ADIF export to generate an ADIF file sorted by the date and time of the QSOs.
Is it possible ? if not, would it be possible to consider this function for a future version?
Thank you
Pb ADIF Log4OM.txt
(5.92 KiB) Downloaded 110 times
Dan - F6FLU
https://F6FLU.org
Re: ADIF export file is not sorted according to the Qsos date
added a default sort
F6FLU
Post by F6FLU »
Dan - F6FLU
https://F6FLU.org
F6FLU
Post by F6FLU »
in version 2.18 it is almost corrected but not exactly, the export in ADIF is sorted on the dates but in reverse order; that is, the first QSO exported is the last QSO performed.
moreover this is not corrected in CSV export. In CSV we have the same problem as the one reported in ADIF
Dan - F6FLU
https://F6FLU.org
