Flex 6600M. Latest release Log4OM. OmniRig 1.19.
How do I show both VFOs side by side? In Log4OM's display the top left correctly shows the output of VFO 1 or 2 as selected. However how do I enable Log4OM to show VFO 1 on the left side and VFO 2 on the right side of the display box?
Jeff - G4IUA
Dual VFOs
Re: Dual VFOs
Sorry to ask what is probably a very basic question...at least to those experienced with these apps. How do I use Hamlib and Slicemaster with the Flex? I have downloaded Hamlib from Github but I'm not even sure how to install and set it up. Will it happily coexist with Omnirig? I already have Slicemaster up and running. If there are any setup instructions they would be very useful.
Thanks!
Thanks!
Re: Dual VFOs
Hamlib is included in Log4om
See the slicemaster user guide 're TCP connection for CAT
Re: Dual VFOs
Can you elaborate a bit? I've tried both the hamlib/slicemaster combination and omnirig (rigs 1 & 2) and have yet to get both displays simultaneously as shown in the Log4OM user manual with my Flex 6600. I can select either rig 1 or 2 to display on the left side, but nothing appears on the right display.
Re: Dual VFOs
We dont show an image of Log4OM with both VFO's displayed when using a Flexradio, see page 196 >>>> of our user guide.WR0H wrote: 11 Nov 2021, 03:08Can you elaborate a bit? I've tried both the hamlib/slicemaster combination and omnirig (rigs 1 & 2) and have yet to get both displays simultaneously as shown in the Log4OM user manual with my Flex 6600. I can select either rig 1 or 2 to display on the left side, but nothing appears on the right display.
Log4OM follows the active receiver Rig 1/2 only when using slicemaster and Hamlib, not Omnirig. as far as I recal the display of both VFO's is only when using a SunSDR which has TCI or some of the more recent physical radios which provide that facility.
I can only refer you to our user guide and the slicemaster user guide for detailed instructions because I do not own a Flexradio, however you might like to contact your fellow countryman Dale Southard - AE6DS who wrote the instructions in our user guide for further information.
Re: Dual VFOs
Thank you for the clarification. FWIW, I was using page 23 as a guide.G4POP wrote: 11 Nov 2021, 07:55We dont show an image of Log4OM with both VFO's displayed when using a Flexradio, see page 196 >>>> of our user guide.WR0H wrote: 11 Nov 2021, 03:08Can you elaborate a bit? I've tried both the hamlib/slicemaster combination and omnirig (rigs 1 & 2) and have yet to get both displays simultaneously as shown in the Log4OM user manual with my Flex 6600. I can select either rig 1 or 2 to display on the left side, but nothing appears on the right display.
Re: Dual VFOs
Solution: when setting up hamlib, check the "CHECK VFO MODE" checkbox. Now when running split, both VFOs are shown.WR0H wrote: 11 Nov 2021, 03:08Can you elaborate a bit? I've tried both the hamlib/slicemaster combination and omnirig (rigs 1 & 2) and have yet to get both displays simultaneously as shown in the Log4OM user manual with my Flex 6600. I can select either rig 1 or 2 to display on the left side, but nothing appears on the right display.
