LOTW upload stuck
Posted: 18 Nov 2021, 10:12
by VK4FDB
Thanks for all your hard work guys. Big fan of LOG4OM.
Got a problem with LOG4OM stuck on uploading to LOTW
LOG4OM: v 2.18
TQSL 2.59 - up to date as of 18/11/2021
Windows 10
On closing, LOG4OM sticks on Uploading LOTW data (120s timeout).
LOG4OM and TQSL set to 'run as administrator'
UAC is set to off.
Manual TQSL ADIF upload works fine.
Relevant log sections:
Any suggestions on how to troubleshoot next?
Re: LOTW upload stuck
Posted: 18 Nov 2021, 10:29
You need to turn on Trace mode in the help menu for the logfile to show more info.
What have you got checked in the config as below?
Posted: 18 Nov 2021, 11:22
by VK4FDB
This goes on for a long time, checking the flags.
Please find attached my settings.
I've updated them to match your settings, G4POP, but with the same errors.
Posted: 18 Nov 2021, 12:53
1 try not to publish un redacted log files on this forum they contain private info
2. YOU MUST SET TO TRACE MODE to see errors
3. Email me the log file - DO NOT POST IT HERE
Posted: 18 Nov 2021, 12:54
Your posts edited
Posted: 20 Nov 2021, 20:58
by VK2SKI
I had the same problem and tried enabling the interactive mode. When I shutdown a pop up window advised there was a new version of tqsl which I allowed it to install.
I then restarted log4om and disabled interactive mode and it shutdown just fine
