LOTW upload stuck
VK4FDB
LOTW upload stuck
Post by VK4FDB »
Thanks for all your hard work guys. Big fan of LOG4OM.
Got a problem with LOG4OM stuck on uploading to LOTW
LOG4OM: v 2.18
TQSL 2.59 - up to date as of 18/11/2021
Windows 10
On closing, LOG4OM sticks on Uploading LOTW data (120s timeout).
LOG4OM and TQSL set to 'run as administrator'
UAC is set to off.
Manual TQSL ADIF upload works fine.
Relevant log sections:
Any suggestions on how to troubleshoot next?
Re: LOTW upload stuck
You need to turn on Trace mode in the help menu for the logfile to show more info.
What have you got checked in the config as below?
VK4FDB
Post by VK4FDB »
This goes on for a long time, checking the flags.
Please find attached my settings.
I've updated them to match your settings, G4POP, but with the same errors.
1 try not to publish un redacted log files on this forum they contain private info
2. YOU MUST SET TO TRACE MODE to see errors
3. Email me the log file - DO NOT POST IT HERE
Your posts edited
VK2SKI
Post by VK2SKI »
I had the same problem and tried enabling the interactive mode. When I shutdown a pop up window advised there was a new version of tqsl which I allowed it to install.
I then restarted log4om and disabled interactive mode and it shutdown just fine
