For some reason my setup to WSJTX & JTALERT stopped working.
After much experimenting this is what I have working.
Comments/improvements please!
WSJTX normal 2237 setup
JTALERT normal Enable logging, 2237
and
last QSO API enable port 2236 include adif header
Log4OM
UDP_INBOUND ADIF_MESSAGE 2236 JTALERT
Why WSJTX did not like the Log4OM port 2237 escapes me.
73, Bo W4GHV since '54
My WSJTX-JTalert-Log4OM setup
https://www.qrz.com/db/W4GHV
Re: My WSJTX-JTalert-Log4OM setup
Bo,W4GHV wrote: 23 Nov 2021, 18:31 For some reason my setup to WSJTX & JTALERT stopped working.
and
Log4OM
Just doing a quick glance at your UDP Port values and looking at the suggested setup configurations in our current User Guide ... I'm not seeing a match.
Check out the current User Guide starting on Page 201. It starts with a direct connection between WSJTX and/or JTDX and Log4OM2. Then steps are noted when you add JTAlert into the mix.
