All of a sudden the .ADI file generated by LOG4OM V1 has MyITU and MyCQ values reversed. Station info shows correct values and TQSL station shows correct values. Where do these numbers come from and how are these number reversed?
Thanks;
Bill W2PKY
MyITU MYCQ values are reversed in .ADI file where do these values come from?
Re: MyITU MYCQ values are reversed in .ADI file where do these values come from?
Bill,w2pky wrote: 27 Nov 2021, 15:57 All of a sudden the .ADI file generated by LOG4OM has MyITU and MyCQ values reversed. Station info sow correct values and TQSL station shows correct values. Where do these numbers come from and how are these number reversed?
Thanks;
Bill W2PKY
Check: Settings / Program Configuration / User Configuration / Station Information
Set your ITU / Zone at that location.
You can also see your settings when looking at the QSOs on the QSO Manager section. Assuming you have the columns listed for viewing for MyCQ and MyITU zones.
I just did a double-check on mine and I was OK on the Station Information and also OK in the QSO Manager and I also exported a number of QSOs to an ADI file and my zone values for CQ and ITU held solid.
I am running V1 Log4OM do not have: Settings / Program Configuration / User Configuration / Station Information
In Station info MyITU is set to 8 and MyCQ = 5 but in the .ADI it's reversed.
Bill,w2pky wrote: 27 Nov 2021, 16:43 I am running V1 Log4OM do not have: Settings / Program Configuration / User Configuration / Station Information
I can't help you with Version 1 of Log4OM. I no longer have it on my computer.
Terry might be able to help out, but I would not hold my breath that he also still has it installed on his PC.
You might consider downloading and installing Version 2 of Log4OM.
Thanks Nolan-
Will probably try to upgrade to V2.
Bill W2PKY
Bill W2PKY
Please read the v2 quick start guide, then read it again!
Bill,
Check your e-mail I've sent you a message with some information about moving to Log4OM V2.
I moved to V2 and have the same problem with the ITU & CQ values reversed. Station information in settings is correct. Running Win11 on a new computer. Have uninstalled and erased the APPdata/roaming/Log4om2 directory. Can't figure out the problem
Bill,w2pky wrote: 05 Jan 2022, 01:33 I moved to V2 and have the same problem with the ITU & CQ values reversed. Station information in settings is correct. Running Win11 on a new computer. Have uninstalled and erased the APPdata/roaming/Log4om2 directory. Can't figure out the problem
It will be helpful if you post some screen clips of your Station Information tab from the Configuration.
Also a screen clip of the reversed values you are noting. Is that reversal appearing in your list of recent QSOs? Assuming you have both the ITU and CQ columns tic'd for display in that Recent QSO's (F7) panel.
This Forum can accept up to 3 JPGs posted per reply.
Could the imported data have been incorrect?
