I see on the bottom right hand side of the log it says, "max 5000."
Is that the limit of my log? If so, can I change that to 10,000 or more?
I downloaded the latest version and it says that same thing, max 5000.
I would like to keep only one running log for the primary station if possible.
Barry, KU3X
5000 Q log limitation? Is that it?
Re: 5000 Q log limitation? Is that it?
Barry,ku3x wrote: 08 Dec 2021, 12:32 I see on the bottom right hand side of the log it says, "max 5000."
Barry, KU3X
If you have ~150K QSOs or more you might consider using the MySQL d/b. See Page 17 of the current User Guide for information about that.
As for the 5K record count in the lower right corner see Page 27 of the current User Guide about changing that.
No it is the number of QSO's that will be displayed not the logbook maximumku3x wrote: 08 Dec 2021, 12:32 I see on the bottom right hand side of the log it says, "max 5000."
Barry, KU3X
Searches however search the complete log and not just those displayed
Only 5000 display? I can handle that. Hi Hi When I work a station and look at, "Worked before", as long as the guy I work again is, let's say, number 6000 in the log, I would like it to show up so I know I worked him before and when I worked him.
For what it's worth, this is the best logging software I have used and have no reason to look for a replacement.
Barry, KU3X
Barry, KU3X
For the worked before Log4OM checks the whole database and show you all contacts.
The setted limit is only for the main UI view. In my case i´ve setted this to a max of 200.
