Western Sahara still in the wrong ITU Zone
F5SIB
Post by F5SIB »
Hello;
WS seems to be in 46 not 37
http://www.itu.hamatlas.eu/Strefy_strony/46.htm
https://zone-check.eu/
Bolivia use both 10 and 14 ITU zone
Regards Thierry
Re: Western Sahara still in the wrong ITU Zone
Thierry,
You can make the change in the country.xml file yourself ...
I've done that with my installation. I also kept the original country.xml filename and made a copy and named it: country_user.xml .... Reason for that is when Lele is able to have time to update the core files it won't impact the file I've adjusted and added the _user name.
F5SIB
Post by F5SIB »
KI5IO wrote: 19 Dec 2021, 04:25 Thierry,
Thanks for the information
Best regards
Thierry
