Mount Athos
WB8ASI
Mount Athos
Post by WB8ASI »
I just worked SV2RSG/A. It's probably the pirate, but regardless, Log4OM shows it as Greece whereas my Cluster does show it as Mt Athos. No lookup info for the /A. Had to log as SV2RSG to get lookup data, then change Greece to Mt Athos, and then change to SV2RSG/A and save the QSO. Do I have something set wrong or is just the quirk of the /A? Thanks, Herb WB8ASI
ve3wej
Re: Mount Athos
Post by ve3wej »
with or without the /a, he is on mount athos, so just change the entry manually.. its legit
Dave ve3wej / ve3ie
WB8ASI
Re: Mount Athos
Post by WB8ASI »
tnx and BTW, I got the real Monk. Found my call in his ClubLog.
