Message Service not working
VK7XX
Post by VK7XX »
I noticed that all day yesterday, and again today, that I cannot 'Connect' t the Message Service..... I have asked 2 other VK's and they have the same problem..
Is this a sudden bug, or does anyone know what may be causing the Message Service to currently be not working ???
A server issue or some other problem ???
regards
John
VK7XX
nr0q
Re: Message Service not working
Post by nr0q »
Tag has decided to leave the project forcing us to move the message server. We had to change the address which will require it to be changed in all clients that use the Off Air Message Service including GridTracker and Log4OM.
Matthew NR0Q
GridTracker DevOps/OAMS Server Ops
VK7XX
Post by VK7XX »
nr0q wrote: 21 Dec 2021, 05:53 Tag has decided to leave the project forcing us to move the message server. We had to change the address which will require it to be changed in all clients that use the Off Air Message Service including GridTracker and Log4OM.
Matthew NR0Q
Thanks for the info Matthew... thats a bumma
John
Hi, do you have the new URL?
How to fix chat:
Locate config.ini file in your settings folder (menu HELP -> OPEN CONFIGURATION FOLDER)
Edit config.ini file with notepad or similar, find the row:
[CHAT]
SERVERADDRESS = wss://tagloomis.com
START_PORT = 18260
replace with
[CHAT]
SERVERADDRESS = ws://oams.space
START_PORT = 18360
please note that the prefix changed from WSS to WS only
IW3HMH wrote: 22 Dec 2021, 15:31 How to fix chat:
[CHAT]
START_PORT = 18260
replace with
[CHAT]
START_PORT = 18360
Lele,
Any changes needed/required for the RANGE and/or DEBUG_PORT values?
nr0q
Post by nr0q »
No other changes should be needed.
Matthew NR0Q
VK7XX
Post by VK7XX »
[CHAT]
START_PORT = 18260
replace with
[CHAT]
START_PORT = 18360
thanks for this info Lele.... Made the changes and Chat now working just fine
John
VK7XX
nr0q
Post by nr0q »
Just to tag on to this discussion.
I'm now one the lead developers for the server software that powers the chat function. I'm open to any suggestions for any potential improvements or new features. One I'm interested in implementing is expanding our realtime spits feature to make it something I think would be of more interest to non FT8 operators as well. I currently also operate a DX Spider cluster and will be brainstorming how to bridge the two so we could deliver traditional DX spots with user set-able filters via the same network connection as OAMS.
Matthew NR0Q
VK7XX
Post by VK7XX »
nr0q wrote: 31 Dec 2021, 01:39
I'm now one the lead developers for the server software that powers the chat function. I'm open to any suggestions for any potential improvements or new features. (some text deleted)
Matthew NR0Q
Matthew, would it be possible to have the chat window auto open when someone sends me ( /you) a message ??? I have noticed that in reality, very few people know of the chat feature and even fewer know what the little flashing red square is.... auto opening the window, like the one in jtalert does, would solve this ....
regards
John
VK7XX
