wsjtx/jtalert sync
W4GHV
wsjtx/jtalert sync
Post by W4GHV »
I tried the lengthy approach and got lost.
Here is my 'simple' approach that I understand and WORKS;
Only hitch is that I get an error message even tho the logging occurs correctly.
Log4OM adif import wsjtx 2236
JTalert enable Log4OM logging, do not click send log to log4om
JTalert LAST QSO API enable 2236, include headers
Any ideas on the error message?
Success:!!!! Log mirroring for 2 PCs via Google Drive!!
However, the LOG4OM appears to not be 'realtime'. I have to exit and restart to see changes.
This is NOT a problem since I only use one PC at a time. No 2 computer simultaneous operation YET.
Ideas?
73, Bo W4GHV since '54
https://www.qrz.com/db/W4GHV
Re: wsjtx/jtalert sync
Would help if you showed or detailed the error message
W4GHV
Post by W4GHV »
JTAlert Logging warning
LOG4OM V2 SQLite: Unable to confirm QSO logged.
QSO is still saved in WSJTX log file.
It logs to LOG4OM fine, displays this message and beeps.
Basically the logger is not replying to JTAlert, I guess.
I prefer the simple or understandable method for logging that I got running OK.
But will switch if there is not a simple fix for this.
Loving & learning. Great program
73, Bo W4GHV
Setting in wsjt/JTalert for logging confirmation time out needs changing to longest available
W4GHV
Re: wsjtx/jtalert sync Solved
Post by W4GHV »
Solved. the EASIEST way. Looking at the JTAlert docs.
Nice
TNX W4GHV
