Worked UK Counties
Moderator: OE6CLD
gi0hwo
Worked UK Counties
Post by gi0hwo »
This Award is for working UK Counties on 5 Mhz.
Please keep an eye on this forum for qualification details which we are still deciding upon.
It was very difficult to obtain a definitive list of Counties bot hopefully this is not far out.
If you find any errors or omissions please let me know via email to [email protected]
73 de John - GI8IZB/GI0HWO/EI7JO
Re: Worked UK Counties on 5 Mhz Award
Thank you John, please let me know if the list is stable enough to be included in the next release.
IW3HMH wrote:Thank you John, please let me know if the list is stable enough to be included in the next release.
Yes it is
This is a new award to replace one that was discontinued years ago, I think we should sponsor this award and I am sure John would manage it
Award details
Log4OM Worked all UK counties award
5 MHz UK & European Stations
Bronze - 50 Counties with at least 3 each from GI,GM and GW.
Silver - 70 with at least 4 each from GI,GM and GW.
Gold - 85 with at least 5 each from GI,GM & GW.
Supreme - All 91.
All Band worldwide
Bronze - 40 Counties with at least 1 from each GI,GM & GW.
Silver - 65 Counties with at least 2 each from GI,GM & GW.
Gold - 85 Counties with at least 3 each from GI,GM & GW.
Supreme - All 91
Start date 24th April 2014 - End date: None
Award manager GI0HWO
Award certificate cost to be advised
UKWAC Cert.png (88.14 KiB) Viewed 6912 times
Because the Worked all UK Counties award is in two parts, 5Mhz UK & Europe and All Band Worldwide, John has provided two awards to replace the original, the new award files are attached.
Please download to the C:\..........\Logom\Awards folder ands delete the original "award_60MUKWAC.xml" award
award_UKWAC_ALL_BANDS.xml
This is the All Band Worldwide award
(60.86 KiB) Downloaded 612 times
award_UKWAC_60_METERS.xml
This is the UK & European 60m award
(60.57 KiB) Downloaded 567 times
