I was trying to import an ADIF file with one record and when I click the import button it would do nothing.
I had imported several ADIF files prior and to get around this I copied the entry from the ADI to another ADI file and I was able to import it just fine with it as part of another file.
The ADIF was generated by WSJTX version 2.5.2 and using LOG4OM2 version 2.18.0.0
This does not happen often that I want to import a file with only one record but I figured I would report it. I have worked around the issue and do not need help getting around it.
thanks,
de AC9HP
Unable to import ADIF with single entry
Re: Unable to import ADIF with single entry
Known issue which is fixed in next release and has been reported many times on this forum and Facebook
Its only a file with just one QSO so if there are two or more import will be fine
Adding to Terry's reply here is the link to the thread about the issue ...
https://forum.log4om.com/viewtopic.php?f=32&t=7128
Thank you for the information.
