EQSL download (add not found in log)
NN1D
Post by NN1D »
i see the grayed out check box to add a QSO not found in log using the EQSL download function, how do i enable this box.
TIA
Tony
NN1D
ve3wej
Re: EQSL download (add not found in log)
Post by ve3wej »
I am curious too why its there ( maybe because lotw was added to have this option)... but currently when I have a not found, I just go to eqsl to check it out..
my big question to the qsl programmer, If i do accept 'not found' contacts, does this mean I am confirming the contact, or just a fyi for me to research
I too and curious to the answer to this one
Dave ve3wej / ve3ie
The UI Part of the QSL Manager is always the same for all optionsa (eQSL, LotW, QSL e.g.). This function
ist implemented for the LotW only and that´s the reason that the button is greyed out for all other QSL
services.
I think this function makes no sense on eQSL. Many SWL´s are sending via eQSL bur reception reports are
not for a 2 way log. Also yo receive many cards with a main account but you have logged as /2 or /QRP
as the station was sending the call in the QSO´s. Means you import wrong calls modes (without /2 e.g.)
and have not matched the correct one.
If i receive a No Match i check in my log and on eQSL. Is there a difference i reject the card.
