duplo
va3vf
Re: duplo
Post by va3vf »
PU5MFI wrote: 20 Feb 2022, 19:10 Good afternoon
exists in log40m uma configuration where when I type the callsign if it exists it already accuses it as double? if you have the ability
English version after the Portuguese one:
Nao sei se isso ajuda, mas quando voce entra um indicativo que ja foi trabalhado, independente da banda, ele aparece como um quadrado azul no Stats (F1) tab. Voce pode ver isso tambem no Worked before (F10) tab.
I don't know if it helps, but when you enter a callsign that has already been worked, regardless of the band, it appears as a blue square in the Stats (F1) tab. You can also see this in the Worked before (F10) tab.
