WEIC - Worked EI Counties
Moderator: OE6CLD
OE6CLD
Post by OE6CLD »
Hi all,
Please find attached the award definition for the WEIC - Worked EI Counties. Copy the attached xml file (it should be named award_WEIC.xml) into the <user>/AppData/Roaming/LogOM/awards folder and restart Log4OM.
Claus, EI7JZ/OE6CLD
award_WEIC.xml
(15.97 KiB) Downloaded 647 times
Claus, OE6CLD/DJ0DX/EI7JZ
