Multiples Profiles
ps8cw
Multiples Profiles
Post by ps8cw »
Hi!
I would like to use Log4OMV2 with 2 callsigns and callsigns/p or with different QTHs.
With is the best settings to do for this?
I should use one database with multiples profiles?
Many thanks for any help.
Fernando Rodrigues
PS8CW, PY1FR
Brazil
va3vf
Re: Multiples Profiles
Post by va3vf »
ps8cw wrote: 23 Feb 2022, 13:53 Hi!
Fernando Rodrigues
PS8CW, PY1FR
Brazil
English follows:
Eu criaria um banco de dados para cada indicativo, principalmente se os QSOs nao podem ser agrupados como sendo de uma mesma estacao, como no caso do LoTW.
Outra coisa, eu prefiro usar a versao portable dos softwares, quando disponiveis. Dessa forma fica mais facil the move-los de um computador para o outro, nao deixa residuous no computador ou mudancas no registry, backups sao bem simples de fazer tambem.
I would create a database for each callsign, especially if the QSOs cannot be grouped together as being of the same station, as in the case of LoTW.
Also, I prefer to use portable versions of the software, when available. That way it's easier to move them from one computer to another, no leftovers on the PC/registry, backups are pretty simple to do as well.
