Page 1 of 2
usb & lsb will not match
Posted: 25 Feb 2022, 22:34
by KA5MWB
usb and lsb will not match to log40m2 2.20.0 my radio to icom 7600
thanks
Re: usb & lsb will not match
Posted: 26 Feb 2022, 01:28
by KI5IO
Claude,
What CAT engine are you using? OmniRig or Hamlib?
Some clarification of what you precisely mean about SUB & LSB not matching will also be helpful. Some screen-shots of what you are experiencing will be very much appreciated.
If using OmniRig have you selected the proper rig ini file? There are at least three to choose from in the current OmniRig INI file. See clip below for current IC-7600 rig choices.
You can download the current rig ini zip file from Afreet and install on your computer. But you might already have them installed, but not chosen the right one. Assuming you are using OmniRig for CAT.
Posted: 27 Feb 2022, 03:47
by KA5MWB
i use omnrig
may no make sense you
if i go to 20 meter band and click on 14200 log40 read lsb and radio read14200 lsb
if i go to 40 meter band and click on 7285 log40 read usb and radio read 7285 usb
check offline useing cluster
if on 20 meter i click on a call @ 14113 log 40 read 14113 usb
if on 40 meter i click on a call @ 7285 log40 read lsb
Posted: 27 Feb 2022, 07:57
Click on 14200 where in what program, window or on radio please be specific
Posted: 27 Feb 2022, 08:36
by DF5WW
Go to the Omnirig rig folder. Searcht the .ini file that you´re using with omnirig. Open it with
a editor like Notepad++ and change the CAT codes for USB and LSB.
- icom.png (9.96 KiB) Viewed 1749 times
Posted: 27 Feb 2022, 16:58
by KA5MWB
14200 was on log40 screen i use window 10 version
how do i send a pictures to you?
not good on computer ok
Posted: 27 Feb 2022, 17:14
by KA5MWB
i do not no how to do that i am not good with computer
thanks
Posted: 27 Feb 2022, 22:32
KA5MWB wrote: 27 Feb 2022, 16:58
Where did you click to change frequency and mode???????????????????????????
Was it in another program like WSJT or was it in the Log4OM cluster or somewhere else??????????????????????????????
Posted: 28 Feb 2022, 03:00
by KA5MWB
it was in log40m cluster
Posted: 28 Feb 2022, 08:21
KA5MWB wrote: 28 Feb 2022, 03:00
Try changing the settings on the configuration/CAT - see below
- Untitled.jpg (125.2 KiB) Viewed 1705 times
