Label print selecting filters and multiple callsigns
Posted: 26 Feb 2022, 12:47
by k4em
I'm running Log4OM ver 2.20.0.
When I go into Label print, then select filters, select PULLDOWN, select Callsign, Equal, and enter a callsign, press the PLUS sign. That search criteria shows up in the Query parameters. Now I want to enter a second call sign, I repeat the process, I'm now shown 2 entries that look like this
Check box=checked log.callsign= z22o
Check box=checked log.callsign= z21a
I press the RED plus sign and neither callsign shows up in the Callsign selection window on the main label print screen.
If I select filters and select just one callsign it works, and I can continue and print a label. I just can't select 2 or more callsigns, which is very time consuming.
I think this worked in 2.19.0
Dave
k4em
Re: Label print selecting filters and multiple callsigns
Posted: 26 Feb 2022, 17:31
by KI5IO
k4em wrote: 26 Feb 2022, 12:47 I'm running Log4OM ver 2.20.0.
Dave
k4em
Dave,
Multiple paths to same end result.
You can change the default "and" to an "or" and you can get the callsigns by just using callsign = option. See image below.
Or you can select 'callsign' (as you did) and the choose 'IN' filter selection and then enter your callsigns in the right field that opens up. There were be a brief splash sign advising you to separate each value with a comma.
Enter in the callsigns separated with a comma (I just tried and did not use any spacing) and then do the + sign to add to the query parameter box.
If you made multiple Q's with any/all of those callsigns you can then select which one(s) or all on the filter results QSO Selection Label Print page.
See image below for my test this AM. Let us know how it works out for you.
Posted: 27 Feb 2022, 11:34
by k4em
Nolan,
That worked, very helpful.
Thanks,
Dave
k4em
