IC-7300 Changes filter when cluster click
VK4IM
Post by VK4IM »
Hi
When ever I double click on a DX Spot in the Cluster (F8) tab or or Band Map, my IC-7300 using Omni Rig switches to filter 2 along with band and mode.
It does not matter if I'm in filter 1 or 3 it still switches to filter 2 which I click a spot
Is this an undocumented feature or have I mis-configured something?
Cheers
Re: IC-7300 Changes filter when cluster click
If you search this forum you will find many references to this being caused by an error in the Omnirig .ini file - Contact Alex of Omnirig
