Log4OM Next Gen Speec
ai4gk
Post by ai4gk »
I have been using Log4OM for years and love it! unfortunately, it seems to be operating slower and slower as time goes on. I have an MSI GE72VR laptop with an Intel Core i7 processor and 16 GB of RAM. I typically have other apps running, and my Task Manager shows only 65% memory usage. CPU is about 50%. So, my system is not being taxed significantly. I notice that Task Manager is showing Log4OM 32 bit. I thought there was a 64-bit version. Maybe this is part of the problem?
Thanks,
Dan AI4GK
Re: Log4OM Next Gen Speec
Dan,
What version of Log4OM are you using?
You posted this in the legacy/V1 portion.
If you are indeed using V2 what release are you using? Those details are noted in the top left of the Main UI page and/or you can tap: Help/About and the version number will be there as well.
You noted you have other APPs running. What are those APPs? WSJT-x, Gridtracker, JTAlert, etc., etc.?
What clusters do you have engaged and running with Log4OM?
Log4OM will show up in your Task Manager as being a 32-bit process.
Need some more information before we can offer up any good help for you.
