CWSkimmer and Log4OM
F6FLU
Post by F6FLU »
I would like to use CWSkimmer with Log4OM
That is to say I would like that if I click on a call in CWSkimmer this call is transmitted in Log4OM (in the "CALLSIGN" field)
Is it possible ?
I tried to put "UDP INBOUND MESSAGE_LISTENER 7300 CWSKIMMER" in "Connections" in the settings
but obviously it does not work like that.
Thank you for your advice
Dan - F6FLU
https://F6FLU.org
Re: CWSkimmer and Log4OM
If your using Omnirig then with both Log4OM and CWSkimmer run as an administrator both programs will sync frequency and mode then clicking a spot in CWSkimmer the freq and mode will be synchronised with Log4OM and your radio.
You can display spots from CWSkimmer in the Log4OM cluster but at this time there is no facility to display a clicked spot call sign in CWSkimmer in the Input UI fields of Log4OM
F6FLU
Post by F6FLU »
Thank you Terry for your explanations
Dan - F6FLU
https://F6FLU.org
F6FLU
Post by F6FLU »
@Terry ; would it be possible to integrate this function (facility to display a clicked spot call sign in CWSkimmer in the Input UI fields of Log4OM) in a future version of Log4OM?
Dan - F6FLU
https://F6FLU.org
