Display issue
VE3VEE
Display issue
Post by VE3VEE »
A friend of mine, a new user of LOG4OM, just sent me an email with the attached picture showing a display issue. This happened just after he downloaded and installed a new version, which I'm assuming is version 1.17.1.0. He did not experience this issue with the previous version he had.
He did uninstall his previous version of LOG4OM prior to installing this new one.
Maximizing or resizing the window has no effect on the issue.
Any ideas what he can try?
Thanks,
73 Marvin VE3VEE
novy log 1.PNG (177.75 KiB) Viewed 7307 times
Re: Display issue
Marvin,
Very strange!
Has he changed his screen resolution
Has he tried an uninstall - Re-install
Has he re booted his computer
Has he updated his graphics drivers
PB4FUN
Re: Display issue
Post by PB4FUN »
Have you tried changing your windows theming ?
VE3VEE
Re: Display issue
Post by VE3VEE »
Thanks to both of you for your suggestions. He tested all of them, and at the end he found out the problem was caused by his default font-size in Windows which was set to Medium - 125%. He changed it to 100%, and all was suddenly OK.
Thanks again!
73 Marvin VE3VEE
PB4FUN
Re: Display issue
Post by PB4FUN »
Something the developers should build in now :-)
VE3VEE
Re: Display issue
Post by VE3VEE »
Laco, OM3IM, asked me to mention here that he had no issue with the 125% setting using the previous version of LOG4OM. This issue only appeared after installing the current version. Other than that, he appreciates the improvements in the new version.
Thanks again on his behalf.
73 Marvin VE3VEE
Re: Display issue
Hi Marvin,
space on desktop is the worst nightmare for me.
Keeping compatibility with "small PC" for field use is really hard, i must use every bit of space trying to keeping the user interface simple, clear and with the lower number of tabs to make it simple.
It's a constant battle :)
Daniele
VE3VEE
Re: Display issue
Post by VE3VEE »
Understood, Daniele, things need to be prioritized.
73 Marvin VE3VEE
