Order of Sent and received reports in new QSO
vk1da
Post by vk1da »
I'm just examining Log4OM and like everything I see. However I am puzzled by the sequence of RST Sent and RST Received. These are usually in that sequence and indeed are in that order in the default QSO list. But in the new QSO entry screen area, they are in the other order (Received report, then Sent Report). Is there a way to customise that screen? (I have read about how to customise the fields in the QSO list and other places). I think I will make a lot of errors if they have to be entered in what appears to be the reverse order from the usual.
Andrew
VK1DA/vk2uh
Andrew VK1DA Canberra Australia QF44MO VK2UH Yass QF45LD
Re: Order of Sent and received reports in new QSO
Andrew,
No the input RST fields are some of the fields that can't be customised.
vk1da
Post by vk1da »
thanks for the prompt reply
PB4FUN
Post by PB4FUN »
Unless you decompile, change and recompile again :-)
PB4FUN wrote:Unless you decompile, change and recompile again :-)
Andrew asked if he was able to customise the field order, I replied that it was not possible for a user to do so!
De-compiling and recompiling would be something the author would do not the user!
It's easy to switch them for me, hard coding their position.
If there are a preferred way that collects a wide majority of votes i can switch them
VK7XX
Post by VK7XX »
IW3HMH wrote:It's easy to switch them for me, hard coding their position.
Did anyone vote on this ??? I would like to vole fpr 'Sent' on the left and 'Rcvd' on the right
tnks
John
For me it´s o.K. as it is but also no problem if the sides are changed. ;) :)
ik2egl
Post by ik2egl »
I vote for SENT on the LEFT and RCV on the RIGHT :D
73 de Don IK2EGL
Done in the next release
