CatRadio
iz8ewd
CatRadio
Post by iz8ewd »
CatRadio is the new free radio control software.
It is a perfect companion for Log4OM in the control of the transceiver functions (VFO, mode, filters, band, levels) with a simple mouse click, by using the Hamlib library.
CatRadio download: https://www.pianetaradio.it/blog/catradio/
Configuration with Log4OM: https://www.pianetaradio.it/blog/catradio-e-log4om/
CT1BXX
Re: CatRadio
Post by CT1BXX »
Hi.
Very good to know, thanks for sharing with us. I will give a try.
It looks very interesting. :)
I am using Omnirg + FLRig Radio Kendwood TS990, it has a good option to create and configurate macros in buttons we want/need to command radio.
Again thanks ... very excited with your post. :D
Have a nice day.
73 Manuel Fernando CT1BXX
iz8ewd
Re: CatRadio
Post by iz8ewd »
Hi Manuel, thanks for your reply.
I will add macro buttons as the Hamlib team will add the possibility to send raw commands to the radio from the library, actually this function is not supported and I ask them to add in one of the next releases. Since I'm also contributor for Hamlib, maybe I will work for this update too.
iz8ewd
Re: CatRadio
Post by iz8ewd »
CatRadio 1.3.0 is now available for download https://www.pianetaradio.it/blog/catradio/
Main changes:
- Radio info
- Dark theme
- MIC levels
- NB2
- Meter COMP, ID, VDD
- Yaesu band stack
- Hamlib 4.5
- Bug fixes and various GUI and code improvements
iz8ewd
Re: CatRadio
Post by iz8ewd »
CatRadio 1.4.0
- Auto connect and Auto power-on
- High SWR indicator
- Meter Peak hold
- More serial port configuration parameters
- Bugs correction and GUI optimization
- Update to Hamlib 4.6 beta
Download https://www.pianetaradio.it/blog/catradio/
