Missing Clublog Received column
m0eas
Post by m0eas »
Maybe I am missing something but I can't seen to see a 'Clublog Received' column option per attached screenshot.
v 2.21.1.0
Missing option for Clublog Received.docx
(243.05 KiB) Downloaded 100 times
Re: Missing Clublog Received column
You appear to be correct.
I will check the mantis and see if its been reported and if not will start a new one.
kd0zv
By the way, there is no option at the Clublog server to download verifications. Could be possible that that's the reason that we don't have this row. Downloads for verifications are only possible from eQsl and the LotW.
Thanks Juergen!
DF5WW wrote: 21 Apr 2022, 12:54 By the way, there is no option at the Clublog server to download verifications. Could be possible that that's the reason that we don't have this row. Downloads for verifications are only possible from eQsl and the LotW.
Correct and there is no download provision with HamQTH so you wont find fields for that or Clublog because there is nothing to record!
