Program will not load after a change to DB location
n5if
Post by n5if »
I created a new DB - on the cloud via the SETTINGS. Since I have done so - when starting the program - it just hangs and will not load. The small window opens to state what is happening - then the main screen loads - and then sits there. If I wait long enough it will shutdown on its own. Otherwise I have to kill it.
Is there a way for my to get in via the file structure and change the contents back to a good DB location that I know will work? Anyway to pull I'm guessing the INI file - let me edit it and then load it back or pull it into a totally new install?
Greg
Re: Program will not load after a change to DB location
1. It helps if you tell us what the pop up message says
2. Its probably caused by windows security making the file inaccessible, especially is using One drive
