My references
F6FLU
My references
Post by F6FLU »
I don't understand what is happening, I fill in the "My References" part in the settings and when I look at my callsign in the Awards field (F3) nothing is displayed :
I should point out that it was working fine before.
I'm on version 2.21.1.0
An idea ?
Dan - F6FLU
https://F6FLU.org
Re: My references
I just tested and it works as designed
You add a reference e.g. when on a summit or island and save it
All QSO's that you have while that reference is present in the config will have it recorded in the QSO under the My Reference field.
Usefull for activators where a summit to summit contact scores more points
F6FLU
Re: My references
Post by F6FLU »
yes Terry but why when I type my call I don't see this reference…
Dan - F6FLU
https://F6FLU.org
HB9BRJ
Re: My references
Post by HB9BRJ »
After having entered your references in the configuration, you must add new QSOs to the database. These QSOs will then have your references attached. I'm using this feature since many years when activating SOTA summits. Terry's answer is 100% correct.
Re: My references
F6FLU wrote: 04 May 2022, 10:52 yes Terry but why when I type my call I don't see this reference…
You won't that's not the way it was designed
F6FLU
Re: My references
Post by F6FLU »
G4POP wrote: 04 May 2022, 14:16
It's very strange because it worked well before ...
Dan - F6FLU
https://F6FLU.org
Re: My references
That could not worked before .... If you type in your call to the callsign field Log4OM collects the data
from qrz.com or whatever you are using for the lookups.But on these databases are no informations about
your references. Log4OM did what it made for, if you have logged a contact your references will be stored
in the "My References" ADIF row and not in others.
F6FLU
Re: My references
Post by F6FLU »
DF5WW wrote: 04 May 2022, 15:59 That could not worked before .... If you type in your call to the callsign field Log4OM collects the data
Hello Jurgen
Thank you; yet it seemed to me that I saw this information if I typed in my own callsign.
But hey it doesn't matter I thought I was reporting a pb... :-)
Dan - F6FLU
https://F6FLU.org
