missing sql info
OM6ADK
missing sql info
Post by OM6ADK »
Hi, i am using verion 2.21.1.0. When i open qsl detail i can not see qsl info.
Can you help me?
73 Michal OM6ADK
Re: missing sql info
Restore your database and config as detailed in the user guide under 'Emergencies'
OM6ADK
Post by OM6ADK »
thank you for your reply.
I noticed that the problem is somewhere different. In the attachment i exported 2 QSOs.
QSO with UA6HGM was logged in by LOG4OM2 and i am able to see all QSO info.
QSO with SP5GSM was logged in by Log4OM and the QSO info are missing.
Thank you.
73 Michal OM6ADK
log4om.txt
(5.53 KiB) Downloaded 92 times
73 Michal OM6ADK
In qso manager your using a date range for the search, dont use a date range and search for all that should show all QSO's
OM6ADK
Post by OM6ADK »
I think that is not the problem.
Please see this video https://youtu.be/7NueZeFPLFA
In OSQL manager i can see the QSL info - sent and received status. But in Edit QSO window on the QSL info tab are this info empty.
Here is the same situation in Recent QSO'S grid. https://youtu.be/HBiWK2bg4vI
73 Michal OM6ADK
Please update to Beta 2.22.0.7 here https://www.log4om.com/download/ I just noticed your on a vey old version
OM6ADK
Post by OM6ADK »
tnx Terry, newest version works well.
73 Michal OM6ADK
