I have QRZ and LOTW to be manually uploaded so that I can make sure the QSO data is the way I want it before it's sent. Entries are made on the Log4OM screen and looking in the recent qso tab under the Lotw Sent and Qrz Com Sent columns, the pending QSO's are set to Requested. Pulling up the QSL Manager, I select QRZCOM, click Select Required, then proceed with Upload Selected QSOs. The upload works just fine however the QRZ Com Sent column still shows Requested. If I continue by next picking LOTW, Select Required, the Upload Selected QSOs, again everything works no problem. However, after LOTW gets pushed, the Recent QSO tab gets refreshed and now Lotw Sent and QRZ Com Sent both indicate Yes.
If I repeat this process in the other order by pushing QSOs to LOTW first, then QRZCOM, the QRZ COM Sent remains Requested. The reason I believe it's just a redraw/refresh issue is that if I go back and try to sent those QSOs again to QRZCOM by clicking Select Required, nothing appears as needing sending. So I think internally everything is just fine.
Recent QSO tab redraw/refresh issue?
Re: Recent QSO tab redraw/refresh issue?
Just checked and it is a refresh issue, added to our Mantis list.
Thanks for being vigilant
BTW it really helps and saves us time if you inform us of the Log4OM version number that you use!
Sorry, it's probably too late now but I'm using the latest release of 2.21.1.0.
Rich,aa3c wrote: 06 May 2022, 12:35 Sorry, it's probably too late now but I'm using the latest release of 2.21.1.0.
The latest release is here: https://www.log4om.com/download/
It is V2.22.0.7
