Edit QSO window size does not fit
N5ZY
Post by N5ZY »
Somehow this problem appeared for me and i've tolerated it for quite some time but on ocassion I need to edit something that is out of view..
How can I adjust the window size? This isn't the only window that does not have sliders but certainly the most trouble..
Re: Edit QSO window size does not fit
Marcus,
Are you running your Windows O/S at a larger value than 100% ???
That would be the Scale and Layout option under Display under Settings for your Windows O/S.
Doing such will cause what you have shown with your images.
N5ZY
Post by N5ZY »
Thanks for the reply.
I likely did at one time but it is presently at 100% for scale.
I believe it switched back when I updated to 21H2
(still w10 since my Ryzen 7 isn't on the compatible hardware list yet)
Marcus,
What about another video driver on your PC? Such as NVIDIA?
My laptops are also only good with W10. I can put a bootleg W11 on, but decided to not do that for now.
