Over the years I had 4 callsigns, all those callsigns and the QSO log are all in one adif file.
I noticed that uploading such a log to whatever online weblog storage give me errors about wrong callsign.
Can someone help me to setup my old call signs under my new callsign so that I can upload them in a correct way with the correct working callsign of that time.
Regards,
Kurt
Help with multiple callsigns (4) and log file
Re: Help with multiple callsigns (4) and log file
Your first step is to ensure that the station call, operator call and owner call fields are correctly set for each QSO. This is easily done in the QSO manager by bulk editing
Next step is to ensure that each on line log has each of your calls recorded and seperate passwords/nickname for each identity..
Having done the above set up a seperate config for each identity ensuring that the call and password/nickname are correctly matched in the external resources menu.
Using a common database for all calls is not an issue because on upload you will specify the station call applicable and log4om will select the appropriate qso's
