WAE - Worked All Europe
Moderator: OE6CLD
OE6CLD
Post by OE6CLD »
Hi all,
Please find attached the award definition for the WAE - Worked All Europe award. Copy the attached xml file (it should be named award_WAE.xml) into the <user>/AppData/Roaming/LogOM/awards folder and restart Log4OM.
Please note that if you have worked one of the Z6 stations from Kosovo (not valid for DXCC yet), these contacts are valid for WAE (and for the CQ awards). If you have no DXCC assigned to Z6 (which is the correct way), a list with all entries will pop up and you can chose Z6. If you have these contacts assigned to Serbia (which is not correct), you can chose it there as well.
All the deleted countries like Trieste, Saar, Karelia, etc. are included as well.
Claus, EI7JZ/OE6CLD
award_WAE.xml
(50.58 KiB) Downloaded 617 times
WAE-Worked All Europe.jpg (62.65 KiB) Viewed 4735 times
Claus, OE6CLD/DJ0DX/EI7JZ
