I am using USB K1EL WKmini. Generally works fine, but with one problem. After running cw window I always have to send first even one dot from paddles to get it working. If I try to send a macro first it is held in the buffer but it does not go to the radio. If I press paddles now , the entire buffer with previously selected macros goes to the radio.
No such case with other loggers e.g N1MM etc.
It's not too much of a hassle as long as I remember to always use paddles first. But you understand, if you see a good dx in the cluster ...
