I have made some contacts on 6M using WSJT-X MSK144 Meteor Scatter and Q65. When I checked my log for these QSOs I found that neither one was logged. The mode is not supported in Log4OM. Is there a chance that these "new" modes will be added to Log4OM?
Thanks & 73,
Rory, K5CKS
Modes missing?
Re: Modes missing?
Rory,K5CKS wrote: 01 Jun 2022, 13:27 I have made some contacts on 6M using WSJT-X MSK144 Meteor Scatter and Q65. When I checked my log for these QSOs I found that neither one was logged. The mode is not supported in Log4OM. Is there a chance that these "new" modes will be added to Log4OM?
Thanks & 73,
Rory, K5CKS
You can edit/add the modes as you see fit.
Go to: Settings / Resource Editor / Program Resources Column
Select modelist.csv or satmodelist.txt, etc., etc..
Once you edit the file for your needs it will be saved with the "_user" filename to preserve it going forward.
These are the user editable set of files to help tweak your needs/use of Log4OM V2.
Re: Modes missing?
Great! That is what I was hoping. Deeply appreciate the help.
Rory, K5CKS
Rory, K5CKS
